About to start on my engine rebuild and have some questions which I'll ask on this thread.
This is what i have to work with
So I'm expecting to have to split the cases and see what happening in there.
I've had the barrel cleaned and the bore measures 50.32mm..It's in good shape and also has this stamping...which is?
So what clearance is required between piston and the bore?
Squirt (96) engine rebuilding
"Experience is something you never get until just after you need it"
Little Squirt owner
Little Squirt owner
Re: Squirt (96) engine rebuilding
So it seems the Ace 100 uses same piston? Those that I've looked at have two rings, whereas the old old one from mine has one...Is that any issue?
Little Squirt owner
Little Squirt owner
The DPO (Dreaded Previous Owner) installed a single ring piston to suit his purposes. The toaster tank Squirt came with the 2-ring piston.
