03/99 transmission
Posted: Wed Jun 22, 2016 7:58 am
Greetings
Can anyone tell me if the transmission from a 99RT would work in a 03. From the schematics, it looks like the only differences are the 30T counter shaft 1st gear in the 03 compared to the 31T in the 99, and the main shaft inner race in the 03 transmission. I have a main shaft from both engines, and differences are 4th gear is 11T on the 03 and 12T on the 99 - 3rd gear has 14T on the 03 and 15T on the 99. Does that make 3rd and 4th gear taller on the 99?
Also---Would the 03 engine work in a 99 frame? There is an extra mounting bracket just below the exhaust port on the 03 that the 99 lacks. Do I need to add this bracket to the 99 frame or could I get away without it?
Tom
Tom
