I see pictures of the model 95 with the rear carrier rack. Looks like there are 4 different ones. Item #909030 fits models 90, 92, 92B and 92B+. Item #619030 fits model 61. Item #949030 fits models 94 and 94A and item #999030 fits models 02, 03 and 99.
Which one are you guys using for the Combat Wombat and what is the difference? Anyone put one on the Super Combat?
Rear Carrier Rack for Combat Wombat
Re: Rear Carrier Rack for Combat Wombat
I installed one on my CW from a model 94, Wombat. Not sure about a model 97 or 98.
Mike Perrett
Mike Perrett
The 94 and 95 frames are exactly the same except for some bracketry (horn mount comes to mind), so the carrier rack for the Model 94 is the right one for the Combat Wombat(95). Like Mike, I'm not sure about what might fit on a 97 or 98.
The model 97 Super Combat lacks the hanging dogs ear brackets found on the rear frame loop of the 94 and 95 frames. On the 95 frame they are used to hold the rear number plate bracket on. Nothing to hold the rack up on an SC without welding on a couple of these.
