Crank sizes
Crank sizes
Are there significant size differences between the Model 99 and Model 94 cranks? The crank in my second RT bottom end is rusted solid into the left side casing. Even if I could get it loose, the crank is beyond use.
I have 3 extra Model 94 crank assemblies and was wondering if they are the same size or not. Comments..... ; D Victor
Re: Crank sizes
Nope you can't use a 94 crank in a Toad Engine - pinion gear side dimensions are different and do not allow for the primary kick function.
Re: Crank sizes
Victor,
Are you positive that your crank is beyond repair? Here is one that I pulled two weeks ago. It was rusted tight to the left side bearing. Patience and Kroil worked to separate them. The crank is now refurbished (by Ronald Liddle) and ready to be re-installed. Pretty amazing to me.
Re: Crank sizes
Post by --- »
I would agree with Dale going in. Get it apart first. You might be surprised at how little actual damage there is, but if you don't look, you won't know. The bearings are probably junk, but if the race seating area is clean, and it could be, there isn't much else right there to be damaged by surface rust. Soak it and see.
GMc
Re: Crank sizes
One would suspect that after you have completely pounded the threads off the left end of the crank, that Yeah, it's unusable. Additionally there are a Lot of filings coming out of the left case. I would be happy to just get the case free of the old rusted solid crank. The case was what I'm after. And I still have another 100 crank in the spare parts. This current crank will NOT budge tho! ; D Victor
Re: Crank sizes
Dale, what methods did you use to get that crank loose? I have pounded the $hit out of the crank and heated the cases & still can't get it to budge! ; D Victor
Re: Crank sizes
Just so folks don't think I'm kidding about the crank...... ; / Victor
tvrc18
Re: Crank sizes
Post by tvrc18 »
Can you press the bearing out with the crank still in the bearing then use a bearing puller to remove the bearing?
Terry
Re: Crank sizes
Post by --- »
Okay, since you have destroyed the crank half, I agree it isn't useable.
Never, as in, never hammer a threaded end of anything. Always put a nut on the threads, or two nuts if you have them and they will fit, use a brass hammer or rubber mallet, and when necessary, heat the bearing boss. This is no different than removing a bearing, it just something stuck through the middle of it. If it takes excessive force, don't hammer it at all. Press it out after thorough soaking in a penetrant. It's a wonder you didn't crack the case.
GMc
Re: Crank sizes
Post by --- »
tvrc18 wrote:Can you press the bearing out with the crank still in the bearing then use a bearing puller to remove the bearing?
Terry
Yes.
GMc
Re: Crank sizes
How do you press the crank/bearing combination out? That's a need to know right now! ; D Victor
dcooke007
Re: Crank sizes
Post by dcooke007 »
I will take all the cranks out there that have damaged threads.....assuming the bearing and seal surfaces are in good condition. Damaged threads on the ignition side of the crank are repairable. Best performed in a lathe with adjustable 4 jaw chuck...but with careful workmanship and patience can be done with simple tools.
Danny Cooke
Re: Crank sizes
Post by --- »
Nice work Danny. I am assuming here that if Vic can get his crank out, you could cut the threaded shaft and graft a new shaft as you demonstrated.
Vic, find someone with an arbor press. It will take more time to set up the supports under the case half than it will to press out the assembly.
GMc
Re: Crank sizes
Post by --- »
dcooke007 wrote:... can be done with simple tools
Nothing you did there was simple.
GMc
dcooke007
Re: Crank sizes
Post by dcooke007 »
GMC,
Yes I can use this method to repair Vic's crank.
Danny Cooke
Re: Crank sizes
Cool Danny, I had no idea that could be done!
Max :o
dcooke007
Re: Crank sizes
Post by dcooke007 »
Good condition Hodaka parts are getting harder to find these days. Non traditional ways need to be considered to keep these bikes going. Non traditional but workable and reliable.
Danny Cooke
Re: Crank sizes
Also if to small of a hammer is used you just beat things to death. I would use at least a 16 oz hammer. ------Clarence
Re: Crank sizes
Victor you could get a small press from Harbor Freight, their shipping rates are really cheap. Anyone that wields could make you one and then use a small car jack. For all that you do, it would be handy. Pawn shop? ------Clarence
Re: Crank sizes
Post by --- »
Vic,
Pull the rubber seal on the left side case to get it out of the way. Although the surfaces that need lube are also very tight tolerance and not really likely to allow penetration, I would at least try soaking the bearing boss area and the inner race to crank area with something like differential oil, doesn't take much but does require time to work. Don't use WD40. WD40 is not a penetrating oil. Blaster is, but I would use diff lube anyway for this. I returned a brace and bit to service after it sat in the moss and dirt under a tree in Alaska for 25 years. Rusted solid, but after soaking in a pan of discarded diff lube, it worked perfectly and still does. That stuff penetrates anything.
Leave it set for a couple of days. Heat the boss area with a heat gun or propane torch and press out the whole assembly assuming you have access to a press. If not, substitute a brass hammer of good size, but support the aluminum case to the best of your ability so that as much of the shock as possible is transmitted to and through the bearing boss area, and not the entire case itself. This may require making a support just for this one use, like a 2x10 with a hole drilled through it just a tad larger than the crank weight, and blocked up on the floor or solid bench using two by or four by material to keep the entire crank free of striking anything on the blind side. You want to support the perimeter of the case as close as possible to the crank center so that the case doesn't flex.
Clarence also has a point about hammers. Somethines it is better to use a really heavy hammer and strike once or twice than to use a light hammer and beat on it repeatedly. Since the threads are already gone, I would not use a wood block in between crank and hammer because it dissipates shock. And be careful not to miss your target and hit the aluminum boss.
GMc
Re: Crank sizes
I recommend Kroil. It is the best penetrating oil that I have found. Products such as PB Blaster do not compare. You can find it online or at better fastener stores (Tacoma Screw for example). It is available it both aerosol or drip. The drip is more economical.
Re: Crank sizes
OK Greg & Clarence were right! I heated the case up again with the torch and used a heavier (my framing hatchet!) hammer. The crank came out out, with the bearing still rusted onto it! YEAY! Thanks for all the help!!!
Now o think I need to put a wire brush attachment on my drill to clean out the rust, solidified oil & pieces of melted bearing or whatever those flakes were that came out around the crank! And I have a spare RT crank to boot!!! ; D Victor
