Road Toad Air Cleaner box
OK. I can't figure this one out from the parts schematics. Someone please tell me which bolt holds the top back hole in the air cleaner cover & where on the frame it mounts.
It looks like the one on the back of the battery box is close, but it would mount the air box with interference to the ignition switch. Someone help please! Mine is a Model 99 with the old style tank shape. ; D Victor
olddogs
Re: Road Toad Air Cleaner box
Post by olddogs »
I think you are missing a bracket. The bottom of the air cleaner backing plate mounts to the frame. The top mounts to a triangle shaped plated bracket the goes from the rear tank mount hole to the front upper frame bracket above battery box. It does not bolt directly to the frame.
bchappy
Post by bchappy »
I believe it is #12 in the schematic: http://www.strictlyhodaka.com/Parts-List-Q-s/2133.htm
Thanks Bill! I figured something was missing! I ordered the part now! I'm gonna need it to hold this up correctly! ; D Victor
