175 SL Exhaust Port Bridge
DesertRat54
Post by DesertRat54 »
I've been following the Road Toad discussion re: the relief of the exhaust port bridge. I didn't want to confuse that thread with my question, so I thought I'd open a separate thread with the same question about the 175 SL. I've got a new piston and bore for mine, and will be installing it soon. I assume I should do the same? Same specs?
Thanks.
Bill in VA
Bill in Virginia
Re: 175 SL Exhaust Port Bridge
I would suspect this is going to be necessary for yours as well, if it has an exhaust bridge. Danny was very specific about it being both necessary and eliminated when a new bore job is done. If you know the machinist who did the bore work, ask if he remembered to do this. If he didn't he may offer to correct it for no additional charge. ; D Victor
DesertRat54
Thanks, Victor; I suspected as much.
Bill in VA
Bill in Virginia
Bill, if you're in Virginia, you should get a hold of Danny Cooke! He's there too, I believe in the Virginia Beach area. He can help you with the work you need done and is an excellent Hodaka motor builder! ; D Victor
DesertRat54
Yes, I'll be doing that. I've got Danny on speed dial... Danny, if you're reading this, you can expect a call in the next few days. Thanks again, Victor.
Bill in VA
Bill in Virginia
dcooke007
Post by dcooke007 »
Wow speed dial...moving up in the world! :o :o
Just kidding Bill, happy to assist.
Danny
