Clarke Tank Lid Failure
Zyx
Post by Zyx »
Has anyone seen a Clarke Tank filler lid fail like this? Less than a year old :|
Zyx
Re: Clarke Tank Lid Failure
Post by Zyx »
Repaired temporarily by heat welding using a solder gun and strips of LDPE cut from an oil bottle. So far so good, but the material at the juncture of the threaded body and the cap seal is really thin. Not a sturdy molding. Clarke should be ashamed for their new style cap. Of course, for another $50 you can get billet aluminum. Not.
Why not see if Clarke would replace the cap ?
Us old timers call them gas caps Ashamed ?? A bit hasty, could start your a company and build a better one. Clark has been a great hodaka supporter. Could be you used too much power, if many people are having the problem it will be improved. We can work for people, with people or against them. Trying to be positive---------Clarence
bchappy
Post by bchappy »
I am betting Clark would replace it if you call them and maybe send a picture. They are a first class company.
Zyx
Post by Zyx »
Contacted them before posting. No response by email. Maybe I need to phone. No one else has had one separate?
RichardMott
Post by RichardMott »
AZ,
They usually have someone at Hodaka Days. Bring your cap and I am sure they will take care of it.
Zyx
Post by Zyx »
That's a thought.
bobwhitman
Post by bobwhitman »
AZ - I agree w/the above. The Clarke folks are first rate. they are a small firm and may not always respond immediately to inquiries, but I've always found them to be super responsible. Do try calling, and ask for Janet or Brett.
MWL
Post by MWL »
Do a search on that subject. I don't think you are the first one to have a cap fail.
racerclam
Post by racerclam »
Yep they are good people , I had a couple of pet cock failures both new and old styles and they gladly replaced them at At Hodaka days just by what I dold them. 8o)
JayLael
Post by JayLael »
Lid was overtightened. Must resist urge to crank it down like it's a bridge bolt.
Zyx
Post by Zyx »
Thanks for the tip. It was not tightened much at all. Enough to lightly compress the gasket so it didn't leak, but really, this isn't my first rodeo.
The design is weak, and that's a fact. The material thickness at the point of strain is less than a millimeter. Plus, this is an off road device, not a closet queen. If it can't take the strain of a motocross pit stop, it isn't good enough. I added material to the area, but hot welds on LDPE are less than full strength, so no telling how long my repair will last.
Talked to the folks at Clarke. The cap has a 6 month warranty. The tank is a year old this past April, but sat on the floor until this April, so has only been in service a few months. Given that this is not their first cap failure, the cap is suspect. I have plastic gas cans with caps older than this century and they are still in service, so my thought is that the cap is under engineered. A replacement only puts me back where I was, subject to failure at some future point.
Clarke plans to be at the Hodaka Days event, so I will approach them there about it. I don't necessarily expect a new cap, since this one is out of warranty, but they should consider a redesign to avoid such issues. I also don't like the vent tit. It is slippery plastic, slightly tapered in the wrong direction, and very hard to get a vent tube to stay put. This, too, could be remedied by a redesign.
Zyx
Post by Zyx »
Update. I just got a response from the Clarke folks. They suggested I contact Strictly Hodaka to see what their warranty policy is. I am not surprised by this, but having dealt with customers most of my adult life, I call that a handoff. Like forwarding a phone call but not staying on the line to see if someone else picks up, leaving the customer to deal with voicemail. If necessary, I can purchase a billet cap, but really....
I will chip in and buy you a gas cap. Just so we can get back to the fun part of life-----------Clarence we know you have a positive side
Zyx
Post by Zyx »
I am not complaining about the warranty. 6 months, one year, whatever. It's out of warranty. I get that. My point would be that the cap should NEVER fail due to normal use. Besides, being an independently wealthy retired federal employee, I can afford a new cap. But thanks.
