Wombat 72
Re: Wombat 72
Hello and welcome! How about a picture of your prize?
You can source your parts right on this site by clicking on "Return to Strictly Hodaka" and then "Shop by Schematics". You can select your model, which I assume to be a 94 Wombat and then find your parts. I did look at the two parts that you mentioned and noted a small issue with the schematic. Select picture "D" to see both the coil and the air boot.
Good luck, I think that you will fall in love with the Wombat.
Re: Wombat 72
It it actually missing the coil? Or just missing spark? If so try cleaning the points , sitting for along time can bring on contamination, also a bad condenser is real common. I saaume you allready did a plug change >
Re: Wombat 72
Has no points LOLracerclam wrote:It it actually missing the coil? Or just missing spark? If so try cleaning the points , sitting for along time can bring on contamination, also a bad condenser is real common. I saaume you allready did a plug change >
Taz
Re: Wombat 72
OK so what kind of help are you looking for?taz wrote:Has no points LOLracerclam wrote:It it actually missing the coil? Or just missing spark? If so try cleaning the points , sitting for along time can bring on contamination, also a bad condenser is real common. I saaume you allready did a plug change >
Re: Wombat 72
My bad , was excited and by passed the points LOL Ok pulling apart now to inspect all ...Thankssocalhodaka wrote:OK so what kind of help are you looking for?taz wrote:Has no points LOLracerclam wrote:It it actually missing the coil? Or just missing spark? If so try cleaning the points , sitting for along time can bring on contamination, also a bad condenser is real common. I saaume you allready did a plug change >
Taz
