Battery box install - where's It go?
I've been looking at the fiche but I can't figure out exactly where the Model 03 battery box bolts to the frame under the seat. How about a few clues??? Dan? AZ? Bullfrog? Thanks! ; D Victor
Re: Battery box install - where's It go?
If I remember correctly, they are mounted to the rounded plate (gusset) that is attached to the frame just under the seat/tank junction. There should be two mounting locations on this plate where a bolt will slip through. I don't remember if you use both, or just one of them. I would have to look at the battery box and the mount to tell for sure.
Thanks. So I guess it needs the long bolts to go all the way through either side. I will look at it and figure it out! Thanks! ; D Victor
Yes, long bolts. I believe they were 1 8mm x 80mm bolt and 1 8mm x 70mm bolt.
