swing arm extension
fullchoke
swing arm extension
Post by fullchoke »
Is a swing arm extension a common modification on a 98 Super Rat? Mine has one(1 inch or so) and I'm curious. thanks
Re: swing arm extension
fullchoke wrote:Is a swing arm extension a common modification on a 98 Super Rat? Mine has one(1 inch or so) and I'm curious. thanks
Lets see a picture of how it was done
Zyx
Post by Zyx »
Probably more common on the older models which had short wheelbases to start with. I extended my 100B arm by just under three inches, and it is still fractionally shorter in wheelbase than a stock 97/98 setup. Probably can't hurt if done in a professional manner.
fullchoke
Post by fullchoke »
pictures. it doesn't seem that 1 inch or so would make that much difference, but maybe it does since it was done.
I don't know how common it is, but it's not uncommon. I have heard of some people putting the 03 Wombat swing arm onto their Super Combats and Super Rats, and it is 1" longer than stock (resulting in the same as adding an inch).
