PVL setting
Posted: Sat May 23, 2015 3:46 pm
Greetings
Can anyone suggest a reliable BTDC settting for a PVL ignition on an 03 with a HT3 pipe?
Stock is .094" BTDC.
In the tech tip section, Paul set his example at .114" BTDC.
The 97 spec sheet shows .156" BTDC.
The instructions that came with the PVL are not very specific.
I'm only slightly confused, so any advice would be helpful.
Tom
Tom
