I think I have most of the parts to put an ace 100 together, but one thing I do need is a headlight. The problem is the bulb or sealed beam is 15 watts so not much light, and a price tag that is crazy high, or am I looking in all the wrong places? any good ideas or substitutes?
Headlight for ace 100b
Re: Headlight for ace 100b
Search the forum for headlight replacement, there are less expensive options
Dave
Dave
This post:
http://www.hodakaforum.com/viewtopic.ph ... ight#p4890
Option 3 is the one you will want to pay attention to. Just remove the Honda trim ring and use the Hodaka trim ring instead. Just be careful disassembling. The lens and reflector will come apart when you remove the trim ring. You don't want to let this happen because then you have to make sure that when you put it in the Hodaka trim tring and insert the bulb, the bulb filaments, lens, and reflector are level relative the the ground.
