shifter
deward66
shifter
Post by deward66 »
I have brain fade. Took the shifter apart on my Ace 100 to put bushings in cover. Now I cannot remember how to put it back together. The pictures in the Manuel don't help. If I line up the detentes, then the shifter lever doesn't line up with cam and the detentes are on the wrong side. If you look in the Manuel you can see what I mean. Any ideas? I have several cams and covers and they all are the same even the 90 cover and cam.
Thanks.
deward66
Re: shifter
Post by deward66 »
I figured out the problem. The cases that I have say HODAKA on them and the shift lever is located on the left side not the right side so the ones I have are different than the x-ray picture. Thank you for your reply's. The book I have shows the x-ray picture not the case that I have.
