GAS TANK CLEANING
dirtsquirt74
GAS TANK CLEANING
Post by dirtsquirt74 »
I tried cleaning my Hodaka tank with lug bolts and kerosene. Worked well in the past but this time it left a fair amount of rust granuals. Thinking I didn't buy the original formula. What product is recommended to clean this tank?
Zyx
Re: GAS TANK CLEANING
Post by Zyx »
I have used radiator cleaner and BB's but I would also consider the new water based rust dissolvers you can get at the hardware store, actually work pretty well. Evaporust if I remember the name correctly.
Pep
Post by Pep »
Rustol from SH or Prep & Etch (phosphoric acid) from hardware store - works every time and works fast.
I like fence staples for agitation, good weight and scratch factor, but anything would work.
Laurie
P.S. Most any acid would work - vinegar on the weak side of the spectrum, to Muriatic acid on the harsh side - ton's of info available on the web.
Be sure to rinse with soap or something basic, then I like to follow with Acetone and compressed air for a good dry.
MTRob
Post by MTRob »
I used Metal Rescue, you can get it from Amazon by the Gal. I poured in 1/2 Gal let it soak, moving it around for about a day. Then added BB's, small nuts and bolts. Then Made sure the gas cap was tight and the petcocks turn off. Then I wrapped it in an old blanket wrapped it in duck tape. Put it in my dryer plus added a pillow to make sure the tank was tight in the dryer and turned it on. No heat. I would check on it. After a while all three of my tanks came out clean. That dryer spinning around and around plus the Metal Rescue really cleaned them up.
MTRob
bchappy
Post by bchappy »
Metal Rescue is also available at Home Depot. I have not used it but from what I hear it works about the same as Evaporust which is available at Harbor Freight and Lowes has it in 32oz size.
