Rear Shocks
Posted: Fri Mar 13, 2015 11:55 am
by csuhaclsbb
Has anyone ever taken apart a rear Hodaka shock? Is it possible?
Re: Rear Shocks
Posted: Fri Mar 13, 2015 12:01 pm
by socalhodaka
yes
Re: Rear Shocks
Posted: Fri Mar 13, 2015 2:56 pm
Kelly, tell us more---I've always wondered about that. Any replaceable parts?
Re: Rear Shocks
Posted: Fri Mar 13, 2015 3:29 pm
by socalhodaka
Not really rebuildable, but you can knock the pin out and remove the upper eye. You need to compress the spring and use something soft to hold the shaft to unscrew the upper mount to get the spring off.
Re: Rear Shocks
Posted: Sat Mar 14, 2015 5:38 am
by Zyx
But if replacement parts are not available, and probably aren't, about all you can do is clean the insides and reload the oil. Unless you have access to semi-generic parts that can be made to fit...
Re: Rear Shocks
Posted: Sat Mar 14, 2015 10:11 am
Kelly's response was appropriate for the steel chrome body shocks which came on Hodaka motorcycles. And said in a different way, he was saying -- you can remove the springs by driving out the cross pin and unscrewing the top eye of the shock (use a spring compressor!!!), but that's it. Any further shock disassembly will be irreversible. (The shock body is crimped/welded. Seal is not replaceable. At least for non-machinist, non-welder types of folks.)
Re: Rear Shocks
Posted: Sun Mar 15, 2015 3:58 pm
by Darrell
I also tapped the roll pin to removed my rusty Wombat springs to sandblast the springs and bodies (non-rebuildable) for painting. KSM 340 is the best replacement shock I've seen for the chrome tanks Hodakas. The KSMs look like the originals but they're heavier built, with more fluid capacity, etc. and they dampen both ways.
I bought them at the Hodaka Days 2014 banquet auction, and had no prior knowledge of the brand and model so I wasn't sure if I was bidding on glorified screen door closers, or what. However, in action I find that they are a considerable upgrade, and like I already said they look like OEM if that's important for your restoration.
