Max bore 125 combat wombat?
Posted: Wed Feb 18, 2015 5:52 pm
What was the max oversize bore for the 125 combat wombat. The piston measures 2.25 and it looks like it is stamped 90 over. Was there such a thing? -------- I got all my lighting figured out with gas cheap and all I am going to use a colman lantern taped on with duct tape and a hose clamp for safety . The way I figure it when I'm out of gas I probably do not need lights. Warm and no snow here in the west . 15 miles from Glacier Park .-------------Clarence
Re: Max bore 125 combat wombat?
Posted: Wed Feb 18, 2015 8:34 pm
4th oversize taps out to 2.244" (57mm) -- which is the largest of the OEM pistons. I wonder if the "9" you see in the stamping might be a slightly damaged "4"? The largest oversize piston I've heard of for a 125 Hodie is +.080" - something like 58mm (2.283")
Posted: Thu Feb 19, 2015 2:36 am
by admin
Clarence please flip it over and on the inside of the piston will tell who made the piston. Can you let us know please ?
Posted: Thu Feb 19, 2015 3:42 am
Paul the bottom of the piston has 228 with raised letters and the w with a oval around it. The top of the piston is stamped either 090 or J90----------Clarence A W kinda kike below
Posted: Thu Feb 19, 2015 3:50 am
by admin
Ok thank you Clarence this is an older style Wiseco piston. It is not one of the newer Strictly Hodaka Wiseco pistons. I just was wondering.
Thank you!!
Posted: Thu Feb 19, 2015 4:44 am
by bchappy
Sounds to me like the size of your piston might be a worn down .060" over. Turn the piston around and see if that .090 could be a .060. The old Wiseco pistons came in .060 and .080.
Posted: Thu Feb 19, 2015 4:56 am
by admin
Sorry should have said this previously. No one including Wiseco ever made a +.90 size Hodaka piston. It must be a +.60 the measurement given suggests this. A +.60 Wiseco 125 piston for SH is 2.264"
Posted: Thu Feb 19, 2015 6:32 am
by bobwhitman
Great lighting concept, Clarence! Perhaps you should do an illustrated article for the Resonator Revisited on this, as it would work equally well on all models!
Here in Oregon (San Diego Norte') it is 60 degrees and the daffodils and other flowers are a month ahead of normal.
Posted: Thu Feb 19, 2015 2:24 pm
Hey Clarence,
This is kinda funny but I have this old Wiesco Piston on my desk as a paper weight. (From 40+ years ago – 100cc). It does look like it's a .090 over.
Mine still has the decimal showing it to be a .060. It appears to be stamped on the wrong side of the crown. You're off the hook!
(You owe me one) 8-)
