Greetings
Does anyone know how to repair a bad clip on the choke plunger on a 20mm carb? The section that contacts the grooves has a broken end and will not hold the choke up.
Tom
20mm carb
Re: 20mm carb
Tom,
Does it look like this? If so, contact me and I will put it in the mail to you.
Re: 20mm carb
Thanks for the generous offer. It is very much appreciated, but I have one of those.
The clip I'm having problems with, is the tiny cir-clip on the brass plunger itself.
Here is a photo. I think about half of the clip is missing.
Tom
Tom
Re: 20mm carb
Tom, I see what you are up against now. I have that piece too, but it is missing the rubber boot that fits over the top of it. The clip is good. Same offer applies. Just let me know.
Re: 20mm carb
Wow! Thanks so much. Will be happy to reimburse you for your costs.
I will send an e-mail to the address you have listed in the club directory with my home address.
Tom
Tom
