What year is my Hodaka
Posted: Sat Jan 24, 2015 2:23 am
by JDT
I have a Hodaka with Ace 100 on the crank case but it has a front end of a Steen it was made by AlSport
Re: What year is my Hodaka
Posted: Sat Jan 24, 2015 3:33 am
by thrownchain
Frame number, motor number and a pic would be helpfull.
Posted: Sat Jan 24, 2015 6:03 am
by JDT
My motor number is E19646 have not found the frame number
Posted: Sat Jan 24, 2015 7:01 am
by Zyx
"E" engines are replacement engines ordered as an engine, not taken from a complete bike. With a number that high, seems there should be another letter after the "E" and before the numbers. If not, so be it. There is a list of engine and frame numbers on Stictly Hodaka's main page, right side about two third of the way down. Follow the link to the article that shows these things. Also shows where the frame numbers are found, i.e., left side above the upper shock mount, left side main frame gusset below the steering head, and on the manufacturers build plate on the front of the steering head, assuming it has not been removed or replaced during conversion.
Anyway, nearly all available information on Hodakas will be found on Strictly Hodaka's website. Paul and crew have spent years compiling this information.
Posted: Sat Jan 24, 2015 9:38 am
by JDT
I cannot find a number on the frame anywhere it does have a fiberglass gas tank I will try and post a picture later The front end looks like a Steen do you know anybody that has the shocks for a Steen
Posted: Sat Jan 24, 2015 10:14 am
by Zyx
Nope. Maybe someone more familiar with Steen conversions can say whether the frame is custom, or a made over Hodaka frame. I would bet that Paul knows the answer to both questions. He checks the forum from time to time, or you can write to him internally at "admin."
Posted: Sat Jan 24, 2015 10:27 am
by thrownchain
Steens used Hodaka Ace 100 motors. So you may have a Steens and not a "Hodaka" so to speak. I have 3 sets of shocks off of the Steens projects I'm working on, and they are all junk, all the shafts are rusted beyond any repair. If you look on E bay under Sebac shocks, you may find something that will work for your needs. Are your fenders plastic? Does the seat say Alsport on the backside of it ? Can tell more from a pic.
Posted: Sat Jan 24, 2015 5:18 pm
by JDT
The fenders are plastic and it does have AlSport on the back of the seat. Like I said before it also has a fiberglass gas tank. My father bought me this bike when I was 13 I am 52 now and looking to completely restore it. Now that I have the know-how the time and the money to do it. It was manufactured by AlSport
Posted: Sun Jan 25, 2015 2:24 am
by thrownchain
Steens it is. A lot of stuff for the bike is available. Being a Hodaka motor, everything should be available to do a complete overhaul. Body work is available thru E bay. Shocks may be the hardest to source, but persistence should get you what you need. If you're going to run it I suggest up grading to one of the metal tanks that are available, or be sure to coat your tank as modern fuels and fiberglass don't get along well. There are sources for most anything you may need, just ask and we can point you in the right direction.
Posted: Sun Jan 25, 2015 2:51 pm
by BrianO
JDT,
Look on the top edge of the swing arm mount on the left side of the bike. That is where my VIN is on my Steen. Check out the thread "Steen Serial number"
Posted: Sun Jan 25, 2015 3:19 pm
by JDT
Thanks for all the input and information
