Exhaust pipe compatibility
Hello all, I am in the process of putting together a Hodaka at my school with two boxes of parts that I traded for some roofing work. The engine is a 100cc with a reed inducted top end. The red frame I was given has a very worn number, but I believe it reads "A4168." From looking over all the schematics, I've concluded that I have a muffler that fits such models as the 100 Dirt Squirt(01), 100 Road Toad(02), 125 Wombat(03), 125 Wombat(94A), 100 Dirt Squirt(96,92C), and 100 Road Toad(99). My question is will the pipe I have fit the engine/frame configuration I'm working with? Any help is much appreciated. Cheers.
- RichardMott
Re: Exhaust pipe compatibility
If it is a 3 stud exhaust flange and not a screw on, the flange patterns are all the same. What changes is the inside diameter. I have a Road Toad/ 01 Dirt Squirt exhaust on my 03 Wombat motor. It is in an Ace 100 frame and bolts up fine to the mounts.
Works well for a trail bike.
Ok, thanks for the insight. I forgot to mention that it is a screw on type exhaust flange/nut.
- RichardMott
The screw on is an Ace cylinder. The flange exhaust will not work without an adapter.
