model 61 seat
Yamadaka
model 61 seat
Post by Yamadaka »
Do any other models share the same seat as a model 61
olddogs
Re: model 61 seat
Post by olddogs »
Other late model 100 and 125 seats may work, but none have the cool spring release pull knobs.
racerclam
Re: model 61 seat
Post by racerclam »
Yes other seats will work like lat rat super combat wombat . You just have to wemove the weld nuts from the mounting bracket for the spring pins to work.
Yamadaka
Re: model 61 seat
Post by Yamadaka »
Can you tell me what model #s that would be? Thanks
racerclam
Re: model 61 seat
Post by racerclam »
Happy thanksgiving Ed and everyone else. WEll Ed I would think models 94 94a 95 97 98 and 92c dirt squirt
BrianZ
Re: model 61 seat
Post by BrianZ »
Rich, I think you're confusing Bullfrog with bulfrog.
Yamadaka
Re: model 61 seat
Post by Yamadaka »
Thanks Rich and you too Brian
John
eichco1
Re: model 61 seat
Post by eichco1 »
Like Rich said, you just have to remove the weld nuts from the mounting bracket for the spring pins to work. Or maybe just drill them out.
However, you want to use a 97,98,99,01,02,03 seat for a match to the 61.
The 94,95,96 seat pans have shorter rear brackets, and the pan itself has less overhang in the rear, than the 61 pan.
Here is the seat cover which fits the seats I mentioned and the 61.
http://www.strictlyhodaka.com/ProductDe ... e=979022SC
Mark in Illinois
VMX #492
dirtsquirt80
Re: model 61 seat
Post by dirtsquirt80 »
I wounldnt remove the weld nuts I would drill them out to the size of the pins . the 175 seat does have something welded on right were the nuts are on the other seats. that's what I would do anyway
Yamadaka
Re: model 61 seat
Post by Yamadaka »
Thanks for the info. I'm going to go look at a model 61
Yamadaka
Re: model 61 seat
Post by Yamadaka »
Picked up a model 61 today. Motor is stuck from sitting per p/o.... I put some marvel mystery oil in cylinder and have a heat lamp on it for the night. In case I have to pull the head off am I safe in assuming the pipe needs to come off first?
olddogs
Re: model 61 seat
Post by olddogs »
If this turns out to be a bigger project than you planned, I am looking for a 175 to make into a vintage mx racer. I have a fully restored Model 94 Wombat or one of the very rare DS80s in excellent condition I would be willing trade. Think about it.
Users browsing this forum: No registered users and 20 guests
