Page 4 of 6
Re: 03 patina build
Posted: Fri Mar 12, 2021 4:05 am
by givergas
installing the swing arm shaft / bolt in the swing arm and got to thinking, after reading the description from captain ed on how to tighten the front axle so every thing in lined up , that there just might be a way to go about tighting up the swing arm shaft/ bolt in a proper order. i lined it up tightened the pinch bolt then tightened nut, moves nice, greased up good to go ?. albert
Re: 03 patina build
Posted: Sun Mar 14, 2021 11:26 am
by givergas
some actual progress
Re: 03 patina build
Posted: Sun Mar 14, 2021 2:08 pm
Wow! That looks brand new!!! :ugeek: Victor
Re: 03 patina build
Posted: Mon Mar 15, 2021 12:20 am
by givergas
its amazing what a rattle can of paint and elbow grease can accomplish...
Re: 03 patina build
Posted: Sat Mar 20, 2021 11:12 am
by givergas
off with the spokes! only way i could see to clean it up.
Re: 03 patina build
Posted: Sat Mar 20, 2021 5:55 pm
Looks great! Nice job! :ugeek: Victor
Re: 03 patina build
Posted: Tue Apr 06, 2021 1:51 pm
by givergas
progress so far, looking to add tires and put the engine together in the next month. have a few commitments coming up so will have to find some time its coming along though.....albert
Re: 03 patina build
Posted: Tue Apr 06, 2021 3:10 pm
So this is the second Model 03, right? :ugeek: Victor
Re: 03 patina build
Posted: Wed Apr 07, 2021 12:13 am
by givergas
yes, the first one i got hold of there were a lot of missing parts so picked this one up because it has all the parts that the first one was missing, this one is missing the toggle switch on the on the Handle switch assembly and that's it , soooo put this one together as a fully functional street legal 03 wombat and then make a dirt only with what's left. the top picture is the 2nd one and the bottom picture is the first one ,nice to have projects lined out for a while ...albert
Re: 03 patina build
Posted: Thu Apr 29, 2021 12:12 pm
by givergas
nice day in the shop today had MISTER George hammerbeck came over and help put this 03 motor together. i had my grandson come over and it was a very companionable day. George is a very good mechanic and great person. he had the hodaka shop in our town back in the day , it was nice to see the knowledge transfer from generations. grandson and him hit it off pretty good, grandson and i both learned a lot and enjoyed his company very much we have a little more to do but time ran out so next week we will get together again and put the rest together. very good time ....albert
Re: 03 patina build
Posted: Sat May 01, 2021 2:58 am
What a great experience. Good stuff Albert.
Re: 03 patina build
Posted: Sat May 01, 2021 5:01 pm
Way to go Albert! I’m betting it made all 3 of you very happy!!! :ugeek: Victor
Re: 03 patina build
Posted: Sun May 02, 2021 9:48 am
by givergas
starting to look like a motor
Re: 03 patina build
Posted: Fri May 21, 2021 10:45 am
by givergas
had some time today 40 miles on my ace B+ and tires on the 03 build nice day so far
Re: 03 patina build
Posted: Fri May 21, 2021 11:26 am
Perfect day, Albert!
Re: 03 patina build
Posted: Sat May 29, 2021 3:58 am
by givergas
engine pressure tested with a very good passing grade and put where it belongs
Re: 03 patina build
Posted: Fri Nov 26, 2021 2:04 am
by givergas
wow time flys . after a long summer of wood projects , traveling , getting distracted and screwing around in general im finally finding time to get back to my 03 project. got all the wiring to go though and bring it up to snuff. started with the Handle switch assembly took it apart cleaned it up but missing the light switch and most of the parts that go into it. is there a replacement or a knock off that would work or maybe just hot wire it so it , the head light , stays on all the time and leave it like that . might call terry and see if he has one thats kicking around that has the internal parts that i need ......albert
Re: 03 patina build
Posted: Fri Dec 03, 2021 7:44 am
I know Greg Watkins has repro switches. But he wants like $200 plus shipping, last I asked him. :ugeek: Victor
Re: 03 patina build
Posted: Tue Mar 08, 2022 2:36 pm
by givergas
got a few more pieces of the puzzle together last few days. the Engine stop switch assembly got cleaned up, had to replace a shaft in the speedo, and the Main switch assembly had to be cleaned up , getting the wiring harness on so thought id start by getting all the wires it plugs into on the bike. the harness need some help. its amazing what 45 years will do to wires
Re: 03 patina build
Posted: Wed Mar 09, 2022 11:57 am
by givergas
today was blinker day. lots of spare parts, got a set of front blinkers and i will be able to get a set for the back. one thing that i will do is put some silicone on the ends of the post that bolts on the frame . they were stuffed with dirt and rust and such had to drill them out to clear them up as they need new wire.....albert
Re: 03 patina build
Posted: Fri Mar 11, 2022 6:24 pm
I recently bought one of these! They look like they have all the wires needed. Just may have to test colors for matching up. I haven’t got that far yet with my 03 because of Winter weather. But I thought I’d share it with you for the price! :ugeek: Victor
https://www.amazon.com/QAZAKY-Control-K ... _m_rp_1_sc
Re: 03 patina build
Posted: Sat Mar 12, 2022 4:43 am
by givergas
thanks victor. i ordered some wiring supply's and will be getting there in the near future. and as far as winter weather, i keep a infrared heater going at all times once the temps get below freezing usually late October / November till late spring that keeps the temps in my space , 25' x 35' garage with insulated doors and 2 x 6 walls, in the 40s , then when im working / goofing around i have a 220 electric heater i turn on to get the temp up to a comfortable temp, because if i wait for good temps to work out in my shop i might as well move to an apartment and forget the whole thing ......albert
Re: 03 patina build
Posted: Sat Mar 12, 2022 8:56 am
I’m not that lucky. I did get a 15,000 btu tank mounted propane heater this winter. But I can’t close my garage door, or even if it do the door isn’t insulated. So open once, like to leave to go inside to take a leak and whoosh, there goes all the heat. My north wall also is not insulated and neither is my roof, so heat retention is still an issue. If it’s much below 45*F I can’t heat it above maybe 55*, and the concrete slab floor never really warms up either. So standing on a rug doesn’t help much to provide a buffer to the cold for my feet. Type of shoes don’t matter when the floor is 30*F or colder! In the past it hasn’t been that cold but this year has been colder than normal. :ugeek: Victor
Re: 03 patina build
Posted: Sat Mar 12, 2022 10:17 am
by givergas
well ive have been known to put the heat gun on the floor next to my feet on really cold days.....albert
Re: 03 patina build
Posted: Sat Mar 12, 2022 4:48 pm
Been there! But I don’t have a heat gun. And my garage has 2 outlets which are on the same darned GFCI circuit for my entire house, inside and out! I should probably take out the existing breaker panel and put in a bigger one with enough useable wiring/outlets for my garage. Maybe when it warms up. When I was in college, I took a semester of electrical wiring. I had to install a breaker box and wire up the Model tough in house in the lab, to pass my final exam. And my breaker box is in my garage. :ugeek: Victor
