Case Reed 125 Hodaka Project
thirdstone
Post by thirdstone »
True that the resonant intake theory is not applicable to Reed valves ( so I’m told)
Ed I believe you are correct as far as air movement that’s why I went with the widest pod I could fit, granted it’s not as wide as most flatter filters but it’s not far off . I’m pretty sure none of this matters too much at this point , I’ve run smaller pods out in the breeze with plenty of small bore performance but it’s nice to know that I’ve got a good setup behind the number plates . One day I might compare the two air filter connections with my highly calibrated seat of the pants Dyno .
thirdstone
It looks like I have inadvertently erased some reply’s .Don’t know how that happened .
