Checking cold or warm is up to you. I have no idea if the specs shown in the book were in fact predicated on warm engine, but since the instruction say warm it up first, I would assume you need to check warm. But if it is in spec cold it will be also when warm.
Throttle open otherwise it has a hard time sucking in enough air to pump up the gauge. Try it both ways. You will see the difference. Doesn't matter two stroke or four.
Model 95 new piston rings and bore
