Box Of Parts Came In The Mail!
Ok got a great big box of parts in the mail last night, from Danny Cooke. Thank you, Thank you, Thank you Danny!
The parcel included a replacement OEM Model 03,wring harness with hi/low/horn/turn signal switch, a Model 03 headlight bucket compete with AC/DC switch and reflectors, a pair of shocks, speedo with mounting bracket & ignition switch, the indicator light bar and lamps, the chrome rear rack and tool box, rear turn signals, a pair of OEM shocks, a horn, battery box, the right brake perch with the built in front brake switch, and a few other things I'm sure I'm forgetting!
Now I can work to make the bike street legal! I should be done in a couple of weeks. Still need a speedo cable and a signal flasher but I can order those new! Then I can take the title and bill of sale and get it registered for the first time!
BTW, did I forget to say, Thank You, Danny?!?!?!!!!!!! ; D Victor
dcooke007
Re: Box Of Parts Came In The Mail!
Post by dcooke007 »
I am glad they could be put to good use.....been in my attic for a long time. Hopefully they will clean up for you.
Danny
They already are cleaning up nicely! I sent you images of the rack and tool box on the phone today. I also figured out how to mount the indicator lights on the speedo mount plate. I'm assuming the speedo mounting plate is held on by the handlebar riser clamp bolts? That's what looks like makes sense. I should have asked you if you had the speedometer cable! Oh well, if you do, I could use it. I have the drive mechanism and now the speedo, just no way to hook them together! LOL! Oh Paul!
