Road Toad Spark Arrester
RichardMott
Post by RichardMott »
All,
I got a real shock when getting tech inspected for the Bad Rock Ride at HD15. Found out I had no spark arrester insert in my exhaust. Luckily Rick Vernier kindly lent me one from his Road Toad. Phew!, that would have be bad after coming all the way from Pennsylvania and not be able to ride.
I have a request. Does anyone have an insert they would like to sell? Paul does not have the whole assembly I need.
It is items 65,66 and 67 only. The 96 DS or 01 RT are the same I think.
dirtsquirt80
Re: Road Toad Spark Arrester
Post by dirtsquirt80 »
SILLY QUESTION CAN'T YOU USE THE ONE FROM THE 03 WOMBAT WON'T THEY WORK? I KNOW THEY ARE DIFFERANT PART NUMBERS BUT THOUGHT THEY MIGHT INNTER CHANGE.
RichardMott
My exhaust system is either a RT of a DS. The cylinder flange adapter fits 03,RT or later DS. Not sure if the 03 insert will fit. Does someone else know. I know the RT fits what I have for sure.
rtboone
Post by rtboone »
Greetings
Unless I'm reading it wrong, the parts schematics show that these items are in stock. They should fit the models 94a 99 01 02 03.
Hope the helps
Tom
RichardMott
81-Item# /Fig.R2 -Hodaka Part#_999198 - Sound absorber (inner)
Not available. This is the RT which I think is the most compatible with my muffler. The DS is, but is more restrictive. I was just using the DS picture as an example. This bike has an 03 motor.
rtboone
Post by rtboone »
Try HPI. They have the part #999198 available .
Tom
RichardMott
Thanks all, I have located what I need. I should have it at the next ANF ride in September.
