The 03 Wombat is ready for Hodaka Days
Re: The 03 Wombat is ready for Hodaka Days
That is a great looking bike Kelly. Looking forward to seeing it in just a few days from now.
Real nice , can not wait to finish my 72 ! What size tires you running and how is the clearance ?Thanks ..
Taz
Im running the Dual Sport Cheng Shin C858 350-18 This is a good all around tire for everything I will take this bike on. Plenty of room.
Thank you , do you think the 4.00 same tire would fit ? it would be I'm guessing 1/4" wider on each side ! ?socalhodaka wrote:Im running the Dual Sport Cheng Shin C858 350-18 This is a good all around tire for everything I will take this bike on. Plenty of room.
Taz
- RichardMott
Is it my imagination or do the grips match the tires?
Taz-
Most of us have found that "bigger is not better" when dealing w/tires for these 100s and 125s. The 125s pretty much max out on 3:50s (tho some 400s are no wider) and a tire that can be spun on occasion is usually more effective than a tire which the bike really can't ever break loose. Besides, the bigger tires usually eliminate the possibility of using a (needed) chain guard.
Um, what Bob said.
Please retain your chain guard. The chain serves as an excellent conveyor system to deliver all kinds of nasties to the countershaft sprocket if you remove the chain guard.
. . . and bigger is not necessarily better for small bore rear tires. I know that sounds un-American . . . but it is true.
Thanks Bob ,first off I have no intentions of removing the chain guard or anything else off the bike ! LOL All what you say makes real good sense I I will have to find a tire shop here that has the Kenda K 270 and see if there is much differences in sizes .. Thanks again ...bobwhitman wrote:Taz-
Taz
Just remember that 3.50 doesn't mean 3 1/2 inches wide. It will only be in the neighborhood.
