Silencer
Silencer
Need a silencer/spark arrestor for 1973 Combat Wombat. Any ideas where I can purchase one?
Re: Silencer
Ok great. do you have a part# so I can order one. Thanks Dan
Re: Silencer
Just go to the Web site, select "Shop by Schematics". Then select Combat Wombat and finally the picture of the exhaust. Note the part number that you need then scroll down and purchase it.
Re: Silencer
I'm not sure what parts i need. Is there any way you can tell from the attached photo. .thanks Dan
Re: Silencer
I think you're out of luck. Somebody has sawn the silencer/spark arrestor off.
If you can find another exhaust with a good silencer/spark arrestor you could have it welded back on.
Re: Silencer
Dan,
Brian is right or you might have the later model 95 pipe. I can't tell how long the stinger is from the pic. It looks like the bolt hole for securing the spark arrestor/silencer in the pic but I can't say for certain. The early CW had a flame thrower SA/S and the later had a straight stinger.
Charlie R.
Broken Arrow, OK
Broken Arrow, OK
Re: Silencer
Nevermind! I just found out how to blow up the pics that are posted here. Go with Brian's post as he is correct. A Model 94 stinger and SA/S would make a fine donor!
Charlie R.
Broken Arrow, OK
Broken Arrow, OK
Re: Silencer
Dan, if it's of any help, I have the internals of a flamethrower exhaust. I've also got the rest of the pipe in excellent condition. E-mail me privately if you'd like to follow up.
Bill in VA
Bill in VA
Bill in Virginia
