Epic fail....kinda
Charlie R
Epic fail....kinda
Post by Charlie R »
My first Swenco copy swing arm. I wish I had noticed earlier........
Charlie R.
Broken Arrow, OK
Re: Epic fail....kinda
So, I've examined the photos several times and haven't spotted the "epic fail". What's up?
Zyx
Post by Zyx »
It could be the perspective but one leg looks longer than the other. Since both photos were taken on the diagonal it is hard to tell.
Charlie R
Post by Charlie R »
Ok, I'll have a little fun at my own expense. :oops: The legs are backwards...the axle plate should be on the short end. The swing arm will smack the frame if installed like its currently built. Everybody makes mistakes once in a while, right? :lol: Just glad I seen it before I finished it! Future copies will corrected...
BTW, it's a 2" over Model 93 arm pictured.
Charlie R.
Broken Arrow, OK
rough rider
Post by rough rider »
The next one will be perfect Charlie. You are an awesome fabricator, keep up the good work.! Richard
Zyx
Post by Zyx »
Frankly it looks normal to me. The short end of the bend is toward the swing arm pivot, just as the stock arm is. What is backwards here? I don't see it.
