Rebuild kit for ace 100 mikuni vm2000
Ajf
Post by Ajf »
Does anyone know a source for mikuni 20mm rebuild kits for ace 100 carb? Strictly hodaka says out of stock.
Charlie R
Re: Rebuild kit for ace 100 mikuni vm2000
Post by Charlie R »
A rebuild kit for the OEM 20 mm Mikuni is not available anymore if I'm not mistaken. Others feel free to chime in. Some individual parts (pilot jets, main jets, needle valves) are available through Dennis Kirk (maybe Sudco?). As far as the wear items (needle jet, needle, slide) those parts are gonna be harder to find. You have the option of replacing the OEM carb with a new replacement also.
Charlie R.
Charlie R.
Broken Arrow, OK
If Paul can't replace just the individual parts you need try Niche Cycle supply in Florida. I use them for my non-Hodaka projects and recommend them.
Ajf
Post by Ajf »
Thanks for the tips
