30 mm cerianis
tahoethumper
30 mm cerianis
Post by tahoethumper »
Hello all, I just got some fork seals delivered in the mail that are being installed into 30 mm Ceriani forks. I know this is not specifically a Hodaka part related question, but I figured I'd try here since I know a lot of people here are familiar with these forks. By chance, would anyone know the fork oil quantity spec for these little forks? Thanks !
olddogs
Re: 30 mm cerianis
Post by olddogs »
The old school rule of thumb starting point for any conventional fork is oil level 6 inches from the top, springs out, forks collapsed. Changing weights or levels fine tunes them, but this is where you begin.
Pep
Re: 30 mm cerianis
Post by Pep »
Might not be helpful, but my Pentons use 32mm Cerianis, the spec for fork oil is 135cc in those
tahoethumper
Re: 30 mm cerianis
Pep and Olddogs, thanks for your responses. Both were helpful- much appreciated fellas.
