20mm carb
rtboone
20mm carb
Post by rtboone »
Greetings
Does anyone know how to repair a bad clip on the choke plunger on a 20mm carb? The section that contacts the grooves has a broken end and will not hold the choke up.
Tom
Re: 20mm carb
Tom,
Does it look like this? If so, contact me and I will put it in the mail to you.
rtboone
Re: 20mm carb
Post by rtboone »
Thanks for the generous offer. It is very much appreciated, but I have one of those.
The clip I'm having problems with, is the tiny cir-clip on the brass plunger itself.
Here is a photo. I think about half of the clip is missing.
Tom
Re: 20mm carb
Tom, I see what you are up against now. I have that piece too, but it is missing the rubber boot that fits over the top of it. The clip is good. Same offer applies. Just let me know.
rtboone
Re: 20mm carb
Post by rtboone »
Wow! Thanks so much. Will be happy to reimburse you for your costs.
I will send an e-mail to the address you have listed in the club directory with my home address.
Tom
