Can anyone recommend someone who could repair a case damaged by the chain coming off.
Thanks, Ron
case repair
case repair
Re: case repair
If you're not too picky what it looks like, you can repair it yourself like I did with jb-weld and a piece of roof flashing cut to right size...thorough cleaning and wipe-down with acetone seemed to make jb weld stick good.
a more artistic j-b welder could no doubt do a prettier job.
Note the weather stripping between case and inside cover eventually got soaked with gas and wouldn't stick back in there good next time I removed case. I just cleaned and filled in the gap with silicon sealer, brown because that's what I had.
more step-by step of repair among other stuff here: http://www.flickr.com/photos/29069113@N02/
