Hi folks! I’m working on the free play on my 98 Suoer Rat. I’ve already rebuilt the clutch & it has the standard 95/97/98 clutch kit in it. I also blueprinted the clutch.
But I don’t seem to be getting any free play with ANY shims behind the clutch disc! Usually, on a rebuilt clutch I find I need .025 to .028 in shims to get down to 3/32” of free play. But I’m not getting any free play at all unless I use ZERO shims.
Any ideas? Thx!!!
98 Rat Clutch Freeplay Issue
Re: 98 Rat Clutch Freeplay Issue
Couple of quick things to check. Is the side case gasket new and in good condition (not compressed too much)?
Without starting the engine, pull in the clutch and try kicking it over slowly. Does the clutch disengage and let you kick through without the piston moving?
Verify that you have the correct clutch disc, as there are two different ones?
Verify the thrust washers under the clutch are the right ones (inner one is thick, outer one is thin)?
I recognize that it is totally counter-intuitive . . . but the outside face of the clutch moves "out" (from the center-line of the engine) as the friction disks wear. So . . . if you have a situation where no clutch disc (throw-out bearing) shims are needed to achieve some free play at the engine clutch lever, you have something going on which has "moved" the contact point of the clutch disc (throw-out bearing) "out" - or possibly the pressure piece is too long. You may not have used the proper number of steel plates? If so, put the missing one at the "inside" of the pack shown in the drawing - NOT against the iron hub. The photo/drawing is of the ACE 100 clutch. While details vary for the various 125cc era clutches - the basic operation of the clutch is exactly the same. The second drawing illustrates dimensions of clutch discs (throw-out bearings) which may be important in diagnosing this situation.
Oooops. I don't know why the clutch drawing loaded twice. I'm better with Hodaka clutches than I am with computers.
Ed. I double checked and measured the new style clutch plates. They are also 2.5mm. So I’m putting it back together now.
I’m still getting minimal free play, maybe 3/64” using just a .003 spacer. If I use .08 it’s already locking up the free play. What else can I check? Would the wrong washer under the clutch nut do it? If the washer is too thick?
Slow down. You'll go faster. It's nice that you checked the friction disks thickness - but that is only one detail. How about the steel plates - how many of 'em are in there? Which clutch disc (throw-out bearing) do you have? Is the pressure piece the right length - or did some strange part get in there over the decades? Something is out of whack, just gotta spend a bit of time to find out what.
