73 COMBAT WOMBAT
SEABEEMIKE
73 COMBAT WOMBAT
Post by SEABEEMIKE »
I have a 1973 Combat Wombat and I'm rebuilding the motor, I have removed the primary gear and did not mark it for re assembly as the manual states, :oops: Is there another way to tell which side goes up or down?
Thanks for the assistance.
Mike
Re: 73 COMBAT WOMBAT
Usually, if you look closely, you can see faint marks where the inside rest against the main shaft and bearing and the outside will show marks where the washer rested against it.
