Tachometer
S.M.
Tachometer
Post by S.M. »
Hi everybody.
Does anyone knows how/where to connect the tachometer on a 03 wombat?It has two wires and i dont know the wiring schematic to connect it.
Thanks in advance.
SM
Re: Tachometer
Are you talking about an aftermarket tachometer, as the Wombat didn't come with a tach? Did the tachometer come with any instructions? Is one wire is supposed to go to the ignition wire (hot side) and the other supposed to go to ground?
There are a few different types, so to give you a correct answer, need to know more about the unit.
Re: Tachometer
Are you talking about the speedo? No Hodaka came with a tach from the factory.
S.M.
Re: Tachometer
Post by S.M. »
It is not a native Hodaka motorcycle...its other brand that was equiped with hodaka wombat 125 engines at 80's
S.M.
Re: Tachometer
Post by S.M. »
I found this info......the tachometer is not more then a frequency reader.
https://www.puchklub.at/Home/ForumNew/read.php?2,8026
The question : is there any dedicated wire from the Magneto to connect to the tach?
S.M.
Re: Tachometer
Post by S.M. »
S.M.
Re: Tachometer
Post by S.M. »
I realize that maybe the green wire is the key....does it make sense?
Re: Tachometer
Sorry I can't help, I don't read I'm guessing German.
Why don't you post a photo of the bike you are trying to fit this tachometer to as it doesn't sound like one we are familiar with.
Also, if all you need the tachometer for is to keep track of how high you are revving your engine, etc. have you considered getting one of the aftermarket ones that just reads the spark through the coil wire?
S.M.
Re: Tachometer
Post by S.M. »
Thanks you all my friends.
Maybe the tachometer is damage....cause i connected it to one and another coil and didn't work.
dakanut
Re: Tachometer
Post by dakanut »
dirty_rat wrote: Sat Oct 21, 2023 7:26 am Sorry I can't help, I don't read I'm guessing German.
Yes- id also recommend a Tiny Tach! Works great on an outboard motor too! :)
