Why is it…..
Why is it…..
That you measure an existing piston, rings & cylinder and they all measure within specs, but you put a compression tester on and you only get 85 psi???? Victor
Re: Why is it…..
Vic,
Among other things it could be a glazed cylinder wall. It might need a light honing to restore the hashmarks and allow the rings to work with the oil provide a seal. Good luck.
Re: Why is it…..
A bit of oil in the cylinder AND hold the throttle wide open while kicking thru . . . (?)
Re: Why is it…..
Is it a L ring, has the cylinder been ported, did you lap the head? has it ran at all yet, I like my ring end gap on the tight side. I have one tester that is bad - does not read correctly. --- Clarence
Re: Why is it…..
The first thing to do is make sure your Compression Tester is reading correctly. Check the Ring or Rings in the Cylinder by holding the Cylinder up to a light . If you see any light in between the ring and Cylinder either the cylinder is out of round or the Ring is defective. I recently had this problem with a fresh bored Cylinder. It is a fully Ported +.080 with a Webco piston. The rings were out of round. BUT I had a set of Yamaha rings that were Perfect! The Rings that fit the Webco 52mm Piston are: Yamaha 335-11611-00 (52mm STD). Joe
Re: Why is it…..
Thanks folks for your answers. The following replies are offered…
Ed. Yes correct piston & head combination. It’s an Ace 100 with an Ace head and an Art piston with NPR rings.
Testing was done with numerous kicks with throttle wide open. Multiple tries never went above 85-90 psi.
So I’ll be pulling the cylinder and piston and inspecting with a light from underneath to look for irregularities. These were brand new rings. Piston was not brand new but did have a very tight .004 clearance with the cylinder and no rings. Clearance was measured with the rings just above the exhaust port and not at the very top of the cylinder. Victor
Re: Why is it…..
I'd check compression on a different engine as a way to check the compression gauge, before tearing things down.
Re: Why is it…..
OK! Good idea, Ed! Victor
Re: Why is it…..
Have you tried to start it? Even with low compression you can often start one (might have to push start it). Then, once it has run for a while (giving the rings time to seat in), try a compression test (on cold engine).
Re: Why is it…..
It will not start. Numerous attempts. Probably more than 50 kicks, minimum. Victor
Re: Why is it…..
Not yet. Still working on raffle bike.
