Then the fuse holder vibrated apart. Guessing the fuse grounded against the frame under the seat. Replaced with a mini blade fuse holder and first a 5 amp fuse. Then I checked the wiring diagram. It says the 03 Wombat uses a 20 amp fuse. So, I bought some today. Now has a 20 amp mini blade fuse.
The fuse is in line where it’s supposed to be on the harness, between the positive side of the battery terminal and where it plugs into the double connector containing the red wire coming from the rectifier. Still not getting any lights. No lights, no horn, no signals.
Any ideas? I really need to get this one out of here….
