I was looking for methods to lengthen a swingarm, and could not find much information.
So I decided to bite the bullet and go for it. I was looking for a way to keep everything square and level, and this is what I came up with.
after checking that the swingarm was square and level on each end, I tacked a plate across the end.
Then 2 more plates were tacked to the inside of swingarm.
making everything stable for cutting off the ears.
Lengthining the swingarm
Re: Lengthining the swingarm
a grinder and cutoff wheel was used to cut off ears
2 inch sections tacked in place
plates held ears in line and level2 inch sections tacked in place
all welded up
I added a photo of the finished swingarm, with the bracing for strength.
Swingarm stayed level and square and it wasan't as bad a job as I thought it would be.
Users browsing this forum: ossa95d and 3 guests
