I got my snap ring tool from Danny when I got home last night. With the correct sized tool, the snap ring went on right away. So I finished the countershaft, YEAY!!! And I put the bottom end back together with Yamabond & all the new screws.
I had put this motor together once before, but it turned out I forgot about the bent control shaft. Cylinder went on easily the last time….
But, I had to pull it apart again because I forgot about the bent control rod. “Forget” you say?!?! Well I had bent the control rod so I could push it back into the countershaft, when I was tearing the motor apart for its rebuild. And I forgot about the bent control rod because I had been waiting for parts, it was all the way in the countershaft….blah blah blah. Yep, I know, shouldn’t have been an excuse…
So my correct snap ring tool for the smaller control shaft snap ring arrived, and was on the ground at my front door last night. Birthday party for my 7 year old granddaughter kept us busy most of the day, so I started in on the motor re-assembly after we got home.
After re-assembling the bottom end, I put the lower cylinder gasket on and proceeded to ATTEMPT to slide the cylinder over the piston.
“WTF!!! Why was it being a pain in the butt trying to get the cylinder to slide smoothly and straight over the piston/rings? It went on easy enough last time. Same cylinder, same piston, same rings. Nothing different.
I fought with it over an hour and finally said enough is enough. Frustrations were mounting. I figured I’d go at it again tomorrow. I even heard Ed’s voice whispering “Slow down, you’ll……” Well you all know…. I even tried my old trick of using 2 connected hose clamps to act as a ring depressor. NADA!!!!!
I would appreciate any suggestions anyone wants to offer for a cylinder install over a piston/ring assembly. Even with a dowel to hold the piston relatively straight & plenty of 2 stroke oil on the cylinder walls, I just couldn’t get it to slide down over the piston. I stopped because I didn’t want to damage anything. Hoping that maybe tomorrow it will act like the CW pipe did when I couldn’t get it to line up one day snd tgd next day it just dropped right in place…..
Thanks for letting me ramble on……….
