I bought this CW pipe from a guy on the Hodaka FanClub page. He told me he used it on an Ace for a while. Said he wanted it to go to someone who would use it. Here are some pics….
The header to the front of the expansion chamber look OK, and compare well to my Original CW & pipe… The tab also matches up closely to the rubber pad on the under the tank mount… However, as we get to the last bend and the tail section, she’s way off in location to the frame… Any ideas??? Did someone do something funky to the weld joints on this pipe?
It sticks out way too far on the left side and there’s like zero room for the Carb! I would like to use this pipe, but not sure where to begin to correct it…
This is my reeded CW motor in the 94 Wombat frame. I was given a CW air box for it, which I want to mount, but there’s no way it’s fitting with this pipe the way it is now. And I don’t want to screw up the pipe, although, it looks like a DPO may have already done that.
Any advise on this would be appreciated. If I can’t bring it in, close enough to the frame, I’ll go back to the 94A/03 Wombat style pipe I had on it. Which means finding another round air box because I moved the one I had on this bike to the 94 Wombat I redid this past Fall.
Do give me your best shots!!!
