A New Project Bike!
Re: A New Project Bike!
Oh, case sealer. I use Yamabond 4. I get it from Amazon! :ugeek: Victor
Copperhead is good too, and not goopy.
I got some decals on the battery cover & air box cover! I think the colors look good together! Had do some some color sanding on the tank. One more coat of blue & then I can decal the tank as well! But here’s a first peel! :ugeek: Victor
I also did some minor frame assembly work today. Not a lot because my toes keep getting cold from the concrete. But at least a little!
Mounted horn, ignition coil, voltage regulator & also the chain guard and bash plate. At least a few things got done… :ugeek: Victor
[email protected]
Re: A New Project Bike! headlight
Post by [email protected] »
Victor,
I have a 92B Headlight.
I don't plan to use it since I got a Chrome one W/ 6volt bulb and a off /on switch mounted on it.
It is a Side Tab Mount and was New for $49.00 from BMI Kart and Mini bike parts.
Rick
Moxie 1944
Rick, I have a complete headlight for this bike! So hang on to it for now. Maybe down the road when I’m building my granddaughter’s Ace! :ugeek: Victor
I finished the color sand and final color coat on the tank earlier today! And I just finished the decals on the tank now! Here’s the 3 pieces! Hopefully clear coat soon! It was 58*F today, but snow is predicted for tomorrow with only a high of 37*F. No. Lear coat tomorrow. :ugeek: Victor
[email protected]
Re: Wombat Side Mounted Aircleaner
I also have a Complete Wombat Aircleaner, Filter, Rubber "J" connector Pipe, and Spring Clip.
Since I am using a Battery Box / Key Ign. Switch, I have to use the Old Original Aircleaner.
Moxie 1944
Nice! Maybe offer it on The Hodaka Fan Club page! :ugeek: Victor
mac
Post by mac »
I like the color ! I think it will look great when it’s all together.
looking good victor. did your battery cover come with the bike or did you have to find one.....albert
I bought a used Toad cover from Bruce, as it was missing. I did have the entire air box, just need to order a new filter & ring from Terry! :ugeek: Victor
Got my motor back from the vapor blaster. Ready to start motor rebuild! :ugeek: Victor
Got my bottom end together last night. Today I put on the clutch assembly and installed the kick lever & spring. However, I found that the thin, unthreaded part of the idle gear retention bolt (#49) broke off and the idle gear is floating in the tranny! So now I have to wait for a new retention bolt to arrive. :ugeek: Victor
Victor what is in those other zip lock bags?? ----------- Clarence
Motor parts. I sort them by inside tranny, outside clutch side, outside magneto side, etc. it helps keep all the parts together so things don’t roll off the work bench and end up with the 10mm sockets!
I don’t usually have more than one motor apart, but if I did, it would allow me to keep them separate so they don’t get mixed up. :ugeek: Victor
Got my parts in the mail from Terry! I can now finish the rebuild on this 03 motor. Also finished the front fork rebuild. And the triple trees & forks are back on the frame now, along with bars, perches and dual cable throttle!
I also cleaned up and installed the rear rack & tool box on the bike, thanks to missing parts from Bruce! :ugeek: Victor
Ditcher976
Post by Ditcher976 »
Great job it’s turning out well
Got the motor together but I’m not real sure about this counter shaft. I may open it again and swap it out. Seems every time I put the sprocket nut on, it gets really difficult to turn. :ugeek: Victor
Ditcher976
Do you still have this available for sale Iam in need of one set like this
[email protected] wrote: Tue Feb 15, 2022 5:17 pm I also have a Complete Wombat Aircleaner, Filter, Rubber "J" connector Pipe, and Spring Clip.
That was Rich offering it to me. I don’t have an extra. Which bike do you need it for? I can PM you Rich’s number. He’s in Grants, NM! :ugeek: Victor
I sent you a Private Message via the Club Forum! - Victor
Ditcher976
Got the message I think I replied, your project is turning out really well enjoy seeing the progress
I PM’d you back! Read what I wrote you before you buy a cover! :ugeek: Victor
Talk about frustration! I was working in the front wheel I received with this Model 03 Wombat. I decided since the mud catcher rim went so well, I would cut the spokes off the front wheel, clean and polish the chrome rim & clean and paint the hub, and re-spoke the front wheel. All in all, I put about 3.5 hours into this wheel.
Then I realized it had a conical hub and the spokes I had wouldn’t work. I messaged both Terry Larson and Scott Hatch to see if they had replacement spokes for an 03 front wheel.
I was talking on the phone with Lee Fabry, about spoking a conical hub. Then I asked Alan to send me a pic or 2 of his 250 SL wheel since they were supposed to be the same.
When I saw Alan’s pics, I reslized this wasn’t an 03 wheel. Looking closely inside the brake insert if this hub, I then saw it. A Yamaha logo as well as a part number. Turns out this wheel was for a Yamaha DT 125 and not an 03 Wombat!
I told Terry & Scott and they both told me they would check to see what they had and get back to me on Friday.
As I stated, I had also been talking with Lee Fabry about spoking. When I told him in a message it was a Yamaha wheel, he told me he thought he had an 03 front wheel he didn’t need. He text me a couple of pics. I asked what he wanted for it, and let’s just say it was less than the cost of a set of spokes!
I told him to remove the new knobby tire which was on it because I had a matched set of Enduro tires going on this 03, and to keep the tire and backing plate to save shipping weight, because I had 2 backing plates as well! Lee mailed the wheel this morning!
And, I have a friend who wants the Yamaha wheel & I told him he could have it for postage!
Here’s the wheel Lee is sending me, as well as the Yamaha rim & hub. Crisis averted!!! :ugeek: Victor
03 wheel from Lee
03 wheel from Lee
Yamaha rim & hub
Yamaha rim & hub
Parts arrived from Terry! Yeay! Now I can finish the 03 Wombat motor! Onward!!! :ugeek: Victor
