I haven't found a wiring diagram for my 1976 02 Toad.
Does anyone know the key switch wire colors/codes for this model?
Also can you tell me what "E" is for in the main switch diagram.
Many Thanks..
Charlie
Key Layout for 02 Road Toad
Re: Key Layout for 02 Road Toad
Thanks.. The diagram for the 02 model is not posted yet.
I did not think to consider "E" for ground.
We just got the bike, it has a bad switch, with the wires broken from the switch.
The switch has the same markings as the 99 toad, but the wiring is different.
Charlie
Charlie
Well nuts! I obviously didn't follow the link all the way out...
I am not aware of any difference in the wiring between the 99 and the 02. They have the same switch part number. I do see that the 02 uses the model 01 Dirt Squirt main wiring harness. And, the Dirt Squirts originally came out with the 99 harness and changed mid-production. Interesting...
The diagrams for the squirt are not ready either.
The switch looks the same as the 03 wombat, but my switch has a brown wire, and I had a wire on HL, but the wombat doesn't.
Thanks for you help, it looks as if I am going to be using my meter to research this.
The 99 & 02 Toads gave pretty much the same wiring diagrams. The biggest change for both is adding pink & Grey wires for the added turn signal lights.
Hears a quick, enhanced copy of the 99 Toad wiring diagram! Victor
Thanks for the update.
But my bike has a brown wire attached to the "HL" terminal on the switch.
According to the wiring diagram the "HL" is not even used in the switch. Maybe someone did some "changes".
