Paint
motomac
Paint
Post by motomac »
Need help finding the right paint for the engine case's and covers for a 64 Ace 90
gregg_floren
Re: Paint
Post by gregg_floren »
I don't think the center cases are painted.
Good match for the outer cases (clutch and shift covers )is Duplicolor Aluminum Cast Coat.
motomac
Re: Paint
Post by motomac »
You are right on the center cases thanks for the recommendation on the covers
Re: Paint
I like vapor blasting. Vapor blasting seals the metal pores & you don’t need to paint it! I do the cases, covers, head, intake manifold and dry bead blast the cylinder when needed, do I can paint the cylinder black, if it’s an iron cylinder. This Combat Wombat motor was all vapor blasted. :ugeek: Victor
