Zinc Plating Shop
AKwombat
Zinc Plating Shop
Post by AKwombat »
The two 94 Wombats I am restoring are rusty from sitting outdoors for many years. Can someone recommend a zinc plating shop in the western US? I want to get a bunch of hardware and small parts re-plated. Thanks.
Re: Zinc Plating Shop
Make sure to prep all your stuff good before you take it. I alway wire all the washers and bolts on loops so it’s easier for them at the shop. If you know wash pice is hung on a wire, so this way they don’t have to dig around for the little bolts.
Where are you located?
AKwombat
Post by AKwombat »
I'm in Alaska. There doesn't seem to be any plating shops up here anymore. I can bead blast everything if necessary. Thanks.
Hello, here are two very good chrome shops whom also do zink plating as well.
Ogden Chrome, Salt Lake City, Utah, 801--395--9449
and Metal Plating, Azusa, Calif., 1-626--969--7932
Give ether a call and ask questions Good Luck. Hodakapartsidaho.com
captonzap
Post by captonzap »
I think Eastwood sells a Zinc plating kit for DIY ers
Then YOU can be the plating shop!
JR
AKwombat
Post by AKwombat »
Thank you very much for this helpful info.
danshale
Post by danshale »
Azusa shop is Universal Plating and only does Chrome.
For zinc plating, here's a good shop I use now.
Active Plating, Inc.
1411 East Pomona Street, Santa Ana, CA 92705
Tel: 714-547-0356 • Fax: 714-547-0540
Good and reasonable. They ship and they use a local burnishing shop to prep rough parts as needed. Good work- tell them want clear zinc finish.
AKwombat
Post by AKwombat »
I contacted both of these shops. Thank you for the recommendations.
Chris
rlkarren
Post by rlkarren »
Cache Valley Plating
700 W 200 N, Bay 4
Logan, UT 84321
(435) 755-8000
$65/batch whether it's full or partial. Had a pair of RD350 pipes nickle plated last year for about $150.
The last batch I had done was all the hardware from an Ace 90 and a Chrome tank SR and I was told it was "barely" a full batch.
$0.02
AKwombat
Post by AKwombat »
I sent most of the parts that were originally zinc plated to Active Plating in Santa Ana, CA. They did a nice job. It was more expensive that the shop recommended by Roger above, but my parts were sent to an additional shop for tumbling, which added to the cost. Attached pic of some of the parts.
Chris
gregg_floren
Post by gregg_floren »
Be careful with those replated axles. The coating of zinc can increase the diameter enough that they won't go through the bearings.
Don't ask me how I know ;-)
AKwombat wrote: Sun Aug 29, 2021 7:49 pm I sent most of the parts that were originally zinc plated to Active Plating in Santa Ana, CA. They did a nice job. It was more expensive that the shop recommended by Roger above, but my parts were sent to an additional shop for tumbling, which added to the cost. Attached pic of some of the parts.
Chris
What kind of prep did you do to the parts before sending them?
AKwombat
Post by AKwombat »
All I did for prep was degrease them in the solvent tank. I could have bead blasted everything, but the shop
told me they were going to send them out for tumbling & cleaning either way. We discussed the issue of added thickness to parts during re-plating, and they assured me it wouldn't be a problem. I've had to chase the threads on some of the bolts in order to get a nut to thread on smoothly. We will see what happens when assembling the bearings. I've had that problem before on hardware that was re-cadmium plated.
