I am trying to find a side stand for an 03 Wombat. From the parts list, it seems like it has it's own unique stand.
Is there somebody out then that has an 03 and a 94/95 or Road Toad that they can compare it to?
I suspect that the 03 stand is just longer. It would be much appreciated if I could get a measurement from someone.
Gregg
77 03 Wombat side stand
Re: 77 03 Wombat side stand
I can confirm that a stock 99 Road Toad measures 10 3/4 inches from the center of the mounting hole to the bottom surface of the foot.
Thanks Dale.
Hopefully someone will have an 03 side stand measurements we can compare with.
Gregg
Gregg
My 03 is 12 1/2" from bolt center to bottom of stand. I think it is stock...
Greg, Please give me a call, you may be able to adapt another Kick Stand to the bike you have, some are real close in length and design, and with a little work by a good fabricator you could adapt, Give me a call I will check my inventory and have an suggestion, or try to find someone whom might have a stand that will work. Bruce
Thanks guys.
Very helpful.
Bruce... I will call you.
Gregg
Very helpful.
Gregg
