77 03 Wombat side stand
gregg_floren
Post by gregg_floren »
I am trying to find a side stand for an 03 Wombat. From the parts list, it seems like it has it's own unique stand.
Is there somebody out then that has an 03 and a 94/95 or Road Toad that they can compare it to?
I suspect that the 03 stand is just longer. It would be much appreciated if I could get a measurement from someone.
Gregg
Re: 77 03 Wombat side stand
I can confirm that a stock 99 Road Toad measures 10 3/4 inches from the center of the mounting hole to the bottom surface of the foot.
gregg_floren
Thanks Dale.
Hopefully someone will have an 03 side stand measurements we can compare with.
Gregg
My 03 is 12 1/2" from bolt center to bottom of stand. I think it is stock...
Greg, Please give me a call, you may be able to adapt another Kick Stand to the bike you have, some are real close in length and design, and with a little work by a good fabricator you could adapt, Give me a call I will check my inventory and have an suggestion, or try to find someone whom might have a stand that will work. Bruce
gregg_floren
Thanks guys.
Very helpful.
Bruce... I will call you.
Gregg
