Wombat Carb for Super Rat???
Can you configure a 24mm Wombat pull choke carb to work successfully on a Super Rat? If so, can someone tell me all the changes needed? I have a 24mm Super Rat Carb on my 94. But that’s easier to figure out. Thx! Victor
Re: Wombat Carb for Super Rat???
Looks like I’m able to ID the minor differences! Same needle jet, same jet needle. Change the slide from 2.5 to 2.0; change the pilot jet from 25 to 30; change the main jet from 140/160 to 220! Should work, right? Victor
Well, the Wombat carb is too short front to back to work with the air cleaner joint!
I’ll see how the JB Weld holds tomorrow. Hopefully I can use that second carb! Victor
