Do I measure float height with gasket in or out?
Measuring float height
Re: Measuring float height
gasket out and measure both floats, and only bend the little tab that touches the float valve. ------- Clarence
Sounds good. Thanks
Measuring is one way. You can also invert the carb do the floats are on top & level the float arm to the edge of the bowl. Victor
