Hey there. I can’t figure out what to try. I have a 125 Wombat with no lights I could use some help. I have good spark I re-gapped the points compression is at 51psi I drop a bit of gas in the cylinder and not a sputter. I tried push starting it down a hill but not even a sputter. It was running nice and just quit like you turned off the switch. It should at least backfire any help would be appreciated
Al
Won’t start!!!!
Re: Won’t start!!!!
i hope the 51 psi of compression is a typo, This is way to low for an engine to run.
Re: Won’t start!!!!
I too hope that is a typo on the compression. 151psi would be fine, 51psi not so much.
Re-gapped the points. OK. What gap are they at now? (NOTE: I'm not asking what gap you set them at. I'm asking what gap they measure out at NOW.) What you "set" and what you "got" could be wildly different things.
PS: I always check the firing point with a cheap timing light,, so I KNOW what the actual ignition timing is. (things can move as you tighten the points setting screw . . . and that movement may not be noticed)
Re: Won’t start!!!!
Another possibility is that since it died while running it seized and you were able to kick and push it once it cooled down. A quick seize will smear enough piston to stick the rings in the grooves and kill compression. Did it shut down at idle or while riding?
Re: Won’t start!!!!
olddogs' comment would pair up REAL well with 51 psi compression.
