Welding class...
Re: Welding class...
Bruce. They didn’t “Certify me” as a welder. They certified me to use their welding equipment. It means I can make an appointment to go to Make Santa Fe, the establishment & use their welding equipment. It did not make me a “Certified Welder!” Victor
Well. The 2nd Super Rat I bought had a broken air cleaner body. So I went back to the place where I took the lessons & used the welder & grinder there.
Did this repair in less than an hour, including, setup, clean up and putting everything away! Didn’t drill the hole until I got home so I could mount & mark it.
Here’s some before & after pics. I hade it sand blasted before I welded it. Victor
looking good Victor. Clarence
Thanks Clarence! I was rather pleased as well! Victor
